Copies the image installed on the active partition to the inactive partition.
| inactive | Copy image from active partition to inactive partition. This includes the .xos image and all .xmod and .lst files. |
| slot | Copy image only on the specified slot. Default is to copy to all slots. |
| slot | Specifies slot number to copy image to. |
By default, for stacks, if a slot is not specified, the image is copied to all slots.
Copying from active partition to inactive partition includes the .xos image and all .xmod and .lst files.
This command can act on any or all slots only from the master. If not from the master, the command can only act on its own slot.
# install image inactive This will overwrite the image installed on the secondary partition with the image installed on the primary partition. Do you want to proceed? (y/N) Yes Copying image to secondary partition... 100% complete. Image installed to the secondary partition successfully.
This command was first available in ExtremeXOS 30.2.
